en respuesta a:
02:31 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-11-2018
02:31 PM
It seems to be a glitch coming from my specific print setup.
The "Scale lineweights" option does not work using the "DWG to PDF.pc3" printer with imperial paper sizes i.e. ANSI D. I tried creating a custom paper size the same size as an ANSI D but in millimeters and the checkbox functions as it should.
It must have to do with how the pdf printer converts between mm and inches internally. Basically, the pdf printer won't let you use the "Scale lineweights" option for metric drawings printed on ANSI sizes. Use ISO paper instead or create custom paper sizes in mm.
