- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I know this topic has probably been discussed in length but I have not found the answer to my specific question.
I set up a layout ANSI D size and my layers have line weights assigned to them. I setup also a half size print on the same layout to B size, but I am unable to get the lineweight to scale with the rest of the drawing.
When i print with the scale lineweight checkbox all the lines become very thin regardless of lineweight.
When I print without the scale lineweight checkbox the lines are as thick as in the full size (as you would expect), which is too thick.
How is that Scale lineweight option supposed to work?? I would have expected my line weights to show half size since the plot scale is set to 1:2, i.e. a 1mm to print .5mm. What am I not getting?
My drawing is started using the acadiso.dwt template, with monochrome.ctb and the plot object lineweight checkbox to on. I also tried using a custom .ctb with lineweight but i still get the same result.
I have attached sample prints to show.
-Alex
¡Resuelto! Ir a solución.
