pendean
en respuesta a: Anonymous
1) None of your layouts are set to use MONOCHROME plot style tables
2) You are using RGB and other colors true colors: MONOCHROME.CTB does not work on these.
Solution: you need to remove all non-ACI colors from layers and objects and start using MONOCHROME.CTB in all of your layouts.
OR
Switch to using MONOCHROME.STB plot style tables like this https://www.landfx.com/docs/cad-basics/plotting/item/2096-stb.html#overview
