361 Vistas, 2 Respuestas
Can loft only 2 crossections out of 3
Hello, I ran into a frustrating problem with loft. I created 2 perpendicular crossections and loft worked, creating a solid object, however it wasn't shaped as expected, so I added 3rf crossection to smooth the appearance further. However loft command just ignores third crossection and works only with initial 2. I attached the file for better representation.
j.palmeL29YX
en respuesta a: Anonymous
See video https://autode.sk/2Uvld6p.
I drew a new spline (approximated on the given geometrie) which I then used as guide.
HTH
cadder
Jürgen Palme
en respuesta a: j.palmeL29YX
I don't know who you are, where you're from, what you did, as long as... well this solved the problem.
Thank you
