Alfred.NESWADBA
en respuesta a: Anonymous
>> When using the desktop app, it began to install
Which update, there exist more than one.
>> It says "The system cannot find the path specified".
Did it also show you the path that is missing? Have you verified if that is really missing or maybe you only don't have enough permissions ... or maybe your antivirus software blocked the download of the setup files?
So you now have a folder C:\Autodesk, is that true?
Within the folder you should find a subfolder (or more) with the current date, which subfolders do you have?
These subfolders, which were created today, should contain the setup files of the update. You might be able to try to start them manually.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
