Alfred.NESWADBA
en respuesta a: Anonymous
Hi again,
is this the situation you'd like to trim:
The horizontal line is the cutting edge and the left vertical should be trimmed? Both is working on my side.
Just be careful about the vertical line(s) ... these are 2 overlapping objects, so you need to use trim twice, or first remove one of these vertical lines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
