sfiforeman
332 Vistas, 2 Respuestas
Huge PDF Export
So, not a huge file, but a huge sheet.
I need to export a big geometric shape at full scale so our graphic designer can do stuff with it in her world.  She wanted it in pdf so I created a custom paper size at 24"x200".   Printing to pdf from model space, select window, select my custom paper size from the drop down, specify save location, and print.  Everything goes well, but when I open the pdf file all I get is a blank paper.  No lines on it.  Objects are on zero layer, black color.  Need any other info?  Someone help?
john.vellek has embedded your image(s) for clarity
john.vellek
en respuesta a: sfiforeman
Hi @sfiforeman,
Which version of AutoCAD are you using? Is it fully updated?
Are you plotting from modelspace or paperspace? I see that you have you scale set at 1:1. As a test, can you indicate that the plot should "Fit" the paper size to see if you have output?
If you share you drawing file I am happy to try this on my side too to see if I have better results.
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
sfiforeman
en respuesta a: john.vellek
Figured out another way to attack the problem on the designer's end.  More than one way to skin a cat...
