jggerth
en respuesta a: Anonymous
Bear in mind that an Apple server is an unsupported platform...  IIRC that setup uses a SAMBA variant for connecting to windows clients, and SMB has some issues with the wonderul world of Windows AutoCAD.
Suggestion no 1 -- did Apple apply any hotrixes/patches/updates to your server?  Can you roll them back to a date when things worked?
Suggestion no 2 --instead of mapopoing drive letters, can you Xref via UNC naming?
Suggestion no 3 -- get a Windows box to netowrk your Acad files.
suggestion no 4 -- sounds like connectivity is getting dropped.  that may indicate some network infrastructure issues - possible a switch with intermittent problems, a questionable cable, mice in the walls gnawing on the cat5.
