12-04-2018
01:01 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-04-2018
01:01 PM
Here's another approach.
A. Create a offset spline to the original
B. Use arraypath to copy a circle (that is position at the start of the spline) at a uniform distance = d (I used 1.5)
C. Use arraypath again to position a copy of the start circle a distance = d/3 along the path.
D. Create a NEW spline shortened by the distance d/3 and use arraypath with a distance of d.
E. Combine B and D.
The block method may not necessarily place both circles on the path.
Note, this procedure require a bit of familiarity with AutoCAD. AutoCAD has a steep learning curve.
lee.minardi
