12-04-2018
12:20 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-04-2018
12:20 PM
I'm not sure if "block" is referring to an AutoCAD tool/technique or if you simply mean use something to measure the space between each cavity.
Using a spacer between each hole along the curve means the holes in the rectangular piece won't line up. This is shown in the example I attached.
As you get further from the edge, the space between each line becomes smaller. There isn't a way to compensate for that in illustrator. It become even more difficult when the punch cavities are offset like in the original example I attached.
