- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
1. We run 1 pc based computer + several mac based in pc emulator mode full time. All systems are encountering the same problem.
2. Yes. We can XREF from local drives.
3. Yes. We can xref from other drives locally and from certain projects on the server.
4. I've created several test folders onto our server for testing. I did this from indivisual operator workstations. New project folders allow xref's. Everything I've tested from scratch works without a glitch.
5. Yes the server is mirrored. Testing that today/tonight.
Everything is pointing towards a server permissions error with the MAC server.
I've toggled users permissions to test things and the new folders work fine.
Its the established folders that have the issue. I cant figure out why they worked before then suddenly stopped on all workstations seemingly overnight.
I have isolated the folders on the server that have the xref issue.
I will copy the trouble folders in a temp directory (test them again) as well as make new ones there (test them again today) and see if the mirroring is the issue tomorrow morning after the backups are completed tonight.
Thanks for the list of things to check. Looks like its more of a MAC server issue than a Autocad software issue seeing as I can create new folders and have no problems with x'refs.
Still awefully frustrating having to work around this issue for 2 weeks and keep up with the workload. lol
I'll have it tracked down by the end of the week. I will post and mark it resolved when its fixed.
