neaton
en respuesta a: Anonymous
For the screen color issue, in Options, Display, Color... the 2D Model space Uniform background color is 23,28,23 and 3D parallel projection Uniform background is Black. 2D Wireframe uses the 2D Model space color and Wireframe uses the 3D parallel projection color.
Nancy
@Anonymous wrote:
My settings tell me that the drawing is 2dWireframe as expected, but are there other settings you know of that perhaps someone has set that has changed the drawing somehow and rendered if differently? For example, if i change the _VSCurrent variable to Wireframe then i can see the outline of the inserted block. In the "good" drawing, 2dWireframe is still the setting and i dont have to change it to Wireframe to see the object.
