en respuesta a: dbroad
Hi
THanks for the reply.
The coloured blocks on the FPMerchandising layer are intentionally all 1x1, an underlying database scales them depending on the value set in the db. I tried changing the units to Inches rather than Unitless but that didnt work either.
The thing that strikes me as different is the quality of the background color in the screenshots i posted initially. The drawing that fails to show the object on insert background color looks...cloudier than the "good" drawing.
My settings tell me that the drawing is 2dWireframe as expected, but are there other settings you know of that perhaps someone has set that has changed the drawing somehow and rendered if differently? For example, if i change the _VSCurrent variable to Wireframe then i can see the outline of the inserted block. In the "good" drawing, 2dWireframe is still the setting and i dont have to change it to Wireframe to see the object.
Wow..that felt like a rant - sorry :cara_con_una_leve_sonrisa: This setting is really frustrating.
