- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
After detaching the missing xrefs, auditing the drawing and fixing the errors, and purging all the unplaced groups, the insert command seems to behave the same for each drawing. Objects drag in both drawings as expected. Dragmode is set to 2 in each.
1)Make sure that whatever you're inserting into each drawing is large enough to see at the scale you are viewing. One block is only 1"x1".
2)Change the no objects visible drawing's units from unitless to inches.
3)Make sure that the insertion points of the blocks you are attempting to insert are close to the visible graphics for that block. (The blocks I tried to insert looked fine.)
4)Make sure that "explode on insert" isn't checked. It wasn't for me. If that is checked dragging doesn't seem to occur.
