Kent1Cooper
en respuesta a: jboyceQPURR
Joining them and then forcing them to be closed will result in four-segment Polylines where you want triangles, and in some cases the added [closing] segment won't be an extension of the adjacent line or arc that you want it to be an extension of.
Use the PEDIT command, Multiple option, select everything [multiple groupings all at once], Join option, and give it a big-enough fuzz factor to cover the maximum expected gap.  Works with Lines and Arcs and whatever may already be Polyline, if any.  That will operate like Filleting all the nearby ends at zero radius.
Kent Cooper, AIA
