jboyceQPURR
en respuesta a: Patchy
I shouldn've mentioned some of the lines are actually arcs - it doesnt seem to like when they are arcs. Also illustrator doesn't export the lines as joined polylines, it's just a bunch of lines. So you'd still have to go through and manually convert each set to a joined polyline. the image attached is a small sample of the file we're trying to fix. everytime an arc meets a line there is a gap. We need to close all the gaps in the file. there are thousands of these.
