11-30-2018
09:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-30-2018
09:29 AM
>> Our company uses Autocad (2014)
But both drawings show that they were created/saved by an none Autodesk application. Which CAD-applications were working on that dwg-files?
Also I get a proxy warning, which might be the reason for some surprises:
>> The object will place and can be seen in the UAT environment but not the PROD
Which object are you referring to? What do we have to do to reproduce this issue?
A reason not to see e.g. parts of a block could be that the layers are off or frozen. So try the "object to place" procedure with all layers on and thawed (just a guess).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
