425 Vistas, 3 Respuestas
Sheet Set Manager - move viewport from one sheet to an other
Hei everyone,
is there any possibility to move one viewport which is connected to an attribute block (name, number, scale) from one sheet to another?  (I use the SheetSetManager where everything is linked)
FYI: I made two versions for a layout to decide which one is better. The first was made out of the original drawing and for the second I copied the original. The second one (made out of copies) is better, but now I can't use the copy for the new layout because the attributes aren’t connected with the viewport (because they are only copies and the links don’t exist, so I only get these ###).
Is there any possibility to get the better layout without creating everything again?
Thank you for your help!
