john.vellek
en respuesta a: DWEN
Hi @DWEN,
Is this issue still happening?
Here are some things to check:
  • Run RECOVER or AUDIT on your drawings
  • If a specific Layout is the issue, check the applied pagesetup for and unusual plot size or plot area.
Additional troubleshooting steps:
  1. Run SHAREVIEW and publish current sheet, 2D-only, no properties
  2. Run SHAREVIEW and publish current sheet, 2D & 3D, no properties
  3. Run SHAREVIEW and publish current sheet, 2D-only, WITH properties and watch task manager for amount of RAM used. If it goes up over 12-15GB then that would likely cause AWS instance to die.
  4. Run SHAREVIEW and publish all sheets, then all sheets with properties
John Vellek
