488 Vistas, 3 Respuestas
Xref map Resulted in Low Quality when Printed as PDF
Hey all,
Been lurking a lot around the forum and cant find a solution to my problem.
I have this dwg file with 1 referenced map, everytime i print to pdf the quality of the ref ends up being way lower than the rest of the drawing. I tried increasing the quality and changing the odf options but that doesnt seem to help at all. I will leave you a picture below and i hope you can help me somehow.
The reference is the map with the smaller numbers, but you can realize as well that the lines have lower quality not to mention that numbers are not even readable.
I was looking for a way of printing the document that dont get me this final result since i usually present some of the projects digitally.
pendean
en respuesta a: Anonymous
"map" is what exactly, a raster image or something else? For the most part your screenshot looks normal except for some LWEIGHT settings you probably need to turn off in the source file and/or your top file if it's not a raster image file.
en respuesta a: pendean
Its a DWG file. Im printing using .13mm (grey) .15mm (the rest) lweight with options DWG to PDF. When i print to A3 they look ok, but i want the pdf to look like if the lines were vectors, but no, quality when i zoom in in the pdf is really low and rough.
pendean
Change/lower your LWEIGHT settings for the PDF output, and choose as large a PDF sheet size as possible if you intent to zoom in a lot in the PDF, instead of a small sheet size.
