john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I agree with Dean's assessment. This model is not simple. I suggest that you explore breaking the model into several files that can be xref'ed.  Then move your layout tabs to individual drawing files that reference your model files.  You can then use publish or even better use SheetSets to produce your PDF(s). You will find the drawing performance will be improved and it will be easier to produce your PDF file(s).  It might be necessary to print individual PDFs of each layout and then Zip them together as appropriate.  The hidden plotting will also create raster content rather than vector which will make the resulting PDF considerably larger.
Lastly, please consider moving geometry closer to 0,0 as that will also help performance.
John Vellek
