- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Please help?
ACT. SURVEY (TAG) - DRONE (TAG) = DIFFERENT (TAG)
I need to put formula
Did you find this reply helpful? If so please use the Accept as Solution
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Then do it?
Paste in a field, type FORMULAR...
There in the editor area, you paste in a field, type Object <selec you blockreference>, choose the attribute,
back in formular field dialog type in -
then paste in a field, type Object <selec you blockreference>, choose the other attribute.
Your formular field (in the formular field editor area) should looks like
{field - link to attribute1} - {field - link to attribute2}
BUT you get no + sign, only the - sign for negative values.
AND you have to do it before you place the 2-999 blockreference (by copy the first blockreference).
Or you need a tool to do this.
Sebastian
