- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> When you say that I should define the absolute
>> Geographic coordinate system
No, I did not mean you should define a coordinate system in AutoCAD (as AutoCAD does not have such an option, only AutoCAD Map 3D and Civil 3D are AutoCAD based products that know coordinate systems).
>> when I add the dwg into ArcGIS do you mead I should
>> define the Projected Coordinates ?
The workflow could be to use the coordinates in AutoCAD which are corresponding to a specific geographic coordinate system. When you then import this dwg-file into ArcGIS you need to inform ArcGIS which coordinate system and units you were thinking about when drawing objects in AutoCAD.
>> In regards to World Files and rasters. I found this tutorial
>> and it seems to be applied to dwg files
Well, I have not seen yet that world files can be used with DWG-files, but may be it's just me not knowing that this could work.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
