11-12-2018
09:06 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-12-2018
09:06 AM
Thank you Alfred for your response.
When you say that I should define the absolute Geographic coordinate system I used in AutoCAD when I add the dwg into ArcGIS do you mead I should define the Projected Coordinates ? If so, yes I already defined the coordinates in ArcGIS after importing the dwg from AutoCAD and it did not work.
In regards to World Files and rasters. I found this tutorial and it seems to be applied to dwg files. Is this incorrect how they are doing it?
https://sites.temple.edu/psmgis/2017/02/17/georeferencing-floor-plans-for-use-in-gis/
Thank you,
