john.vellek
en respuesta a: Anonymous
Hi @fredricfransson123,
The idea is that your program that inserts the pints into the AutoCAD file should use this new block instead of the one it is currently using.  The text would automatically come in as well and show the correct Z values of each of the block insertions.
I don't know anything about your other program so i can't offer much help there.
However, if your other program cannot use my block, you can use it with Design Center to replace all the existing point blocks all at once using the Redefine option.
I made a quick video that shows how this might work.
I hope this gets you closer to where you want to be in this process.
John Vellek
