1288 Vistas, 14 Respuestas
Attribute binded to the z coordinate
I copy a mall because ive been searching for a solution for this problem a very long time..
john.vellek
en respuesta a: Anonymous
HI @Anonymous,
Are the points in your file made of blocks? If so, perhaps you could substitute a block of your own for the existing  ones.
You block could consist of a point mark along with a field that is linked to the insertion point of the mark.
Do you have a sample drawing that you can share so i can take a look?
John Vellek
en respuesta a: john.vellek
yes, i send you a pm
john.vellek
Hi @Anonymous,
How are you inserting the points?  I tried to edit the point block but the attributes do not show up in the block definition.
I have a different block that would give you the Z value of each point automatically if you could use it instead of the Fss-01 block. I have attached it here for you to try.
John Vellek
My points or 3d polylines are inserted with another program who i calculate the survey called "sbg geo". after that i transfer my 3d lines to a dwg file to open up, in this point i want to light up all my z coordinates to attribute, with a (+) on it like the file i sended you, and its all points in the whole file i want to be the same.
The visible attribute on the grey line, i cant tell how that one is done, but you can see it, and it looks awsome, and thats what im serching for to be able to put in my drawings, im googled alot of this and a "lisp" file is comming up alot, but havent find any yet who are able to do this attribute like the picture
john.vellek
Hi @Anonymous,
Can your sbg geo program use the block I provided? Then all the points will have a plus and the text indicating the z value automatically.
John Vellek
1 second, have to download newer version of trueviewer to convert file
This is what i can see in the file, so can you explain what i will make of this "block" you made in autocad to get it working ?. i rather wants to do it in autocad, but give me a new pm or here there road to get to that point, what i need to do in the program with this block you send me!
One more thing, it can be 50 000 points who needs to change to 700 3d polylines with alot of points in each one, so its some automatic im serching for to make it on all points somehow
john.vellek
Hi @Anonymous,
If you can use the block I provided as the point block then it will automatically have the z values. If you move the block then simply do a regen or Field update and eh new location will be updated for the point.
John Vellek
ye so far i got, but the thing is when its 10 000 points, you dont wanna manual put it on every point! i want to make it on all with some command or lisp or someting but how ?
john.vellek
Hi @fredricfransson123,
The idea is that your program that inserts the pints into the AutoCAD file should use this new block instead of the one it is currently using.  The text would automatically come in as well and show the correct Z values of each of the block insertions.
I don't know anything about your other program so i can't offer much help there.
However, if your other program cannot use my block, you can use it with Design Center to replace all the existing point blocks all at once using the Redefine option.
I made a quick video that shows how this might work.
I hope this gets you closer to where you want to be in this process.
John Vellek
thats not what im talking about, but nice video, can you put out a video when all the green lines are with those attributes with z coordinate inside, as i want it ?  ALL points who is green on the dwg i sended you, There is what im serching for! Good Luck!
john.vellek
Hi @Anonymous,
Perhaps I am misunderstanding but I understood that your third party application was able to insert the symbol and attribute you have on the grey lines.
The video you showed also looked like it was able to insert a block as well.
Your green lines do contain nodes (points) but they are not blocks.  They are actually blocks with different names. Is it possible to have them inserted as only a single block? Then you can redfine with my block as I showed in my video. How are they being inserted?  If you have a CSV file with the point data, there are ways in Excel to build a script that would insert all the point blocks to your coordinates.
Please give me some more information on your process.
I created a "library file" with my block with different names ....ptag1, ptag2, ptag3, etc.
I then redefined the blocks in  your file using Design Center.  I will email the file back to you for you to examine.
John Vellek
Here we go, now i hear that you understand what im serching for, I have found out that excel works, i can make the coordinates to csv, pxy but the thing is that i think it take to much time for me, i want to make it like in 1 min for each drawing, a fast way to make it, if i use excel i have to make it csv, add some codes, then in autocad. But sure if its the only way i got no other options to choose!
is this someting you got some tip and trix for ? i can send you a pxy or a csv how it looks like when i turn them in this format!
