dlanorh
en respuesta a: luigiverdenico
Is it used in similar circumstances? Post an example drawing using the "Tubo" block as you did with the "canalina" block.
If it is used in the same way I might be able to use the same lisp for both blocks, where you are asked which block to use. This can be achieved using dynamic input methods so you click on the choice with the mouse with the default choice marked, so by right clicking the default is chosen. I cannot start this until tomorrow mid afternoon my time (European).
I am not one of the robots you're looking for
