11-03-2018
09:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-03-2018
09:35 AM
I have a lisp program that follows drainage runs (a lwpolyline) and extracts the the invert levels from the manhole blocks along its route. This sounds very similar to what you require and could be adapted to suit your need.
1. Are you running full AutoCAD or AutoCAD LT?
2. I would need a drawing containing the block you use, so that I can determine the block tags. If you could supply this in AutoCAD 2010 format.
I am not one of the robots you're looking for
