11-03-2018
03:50 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-03-2018
03:50 AM
Hi all,
I explain you my necessity. I drew cable ways in a plant design as blocks with attributes. In particular every cable way has a code (example: TM001NA, TM002NA, ecc.). Now I have to do the cables routing: an excel document where I write the path of every cable as serie of cable ways codes cross by the cable.
So if a draw a polyline that simulates the path of a generic cable from the start point to the end point through the cable ways, is there a way in autocad to join the codes of cable ways intersected by this polyline and export the result? (example: TM001NA_TM002NA_ecc.).
Thank you for the attention.
¡Resuelto! Ir a solución.
