13584 Vistas, 9 Respuestas
Hatch command doesn't seem to work at all.
I've been working on a project, and strangely, the hatch command seems to have stopped working.  I've tried repairing the program in Windows 10, I've tried to run the FILL:ON command, but nothing so far gets it working.
To Hatch a closed polyline (yes, it is closed, I checked), I type "HATCH", then select the closed polyline, make sure the hatch pattern is what I want (grey, solid, opaque - 0 transparency), then press enter.  This worked as it should, then suddenly it stopped working.  I haven't found anything yet in the Forum that solves the problem.
It's probably something obvious I'm missing, since I'm relatively new at this, but why would it just stop when it was working before?
Thanks for your help.
Tafirkhoo
Etiquetas (1)
