pendean
en respuesta a: Anonymous
So the error message is very specific and can only and truly be fixed inside the TOP file by repathing the XREFs. I'm not sure any 'hotfix' is designed to do that for you.
How does the user PC read the folders on the Server, and what is the OS on this new server?
BTW, if you want Autodesk support, whip out a credit card and select the level you can afford with the features you need http://www.autodesk.com/support-offerings/overview
