pendean
en respuesta a: Anonymous
VPLAYER command has a VPNEW tag you can place on new layers to prevent them from showing up in viewports created afterwards: same in LAYER command's VPNEW column.
Or someone never did what you wanted in the old files.
Or you have a new routine or process being used that changed certain layer settings.
Or your newer imported LAYERSTATES do things differently from the old LAYERSTATES used back in the day in those old files.
Layer settings never change on their own in old files no one has ever touched before you (assuming they were perfect to start with): never.
Do you need help rectifying those viewports? Or you got this one? Let us know.
