597 Vistas, 6 Respuestas
11-02-2018
05:48 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-02-2018
05:48 AM
In the past when i wanted to void a dimension override so that no dimension showed up all i had to do was type in the code, Alt+030 in the text override field and my dimension would disappear allowing me to manipulate the dimension string or notation accordingly. Now in 2019 it seems Alt+030 is not recognized when i type it in. Other alt codes such as Alt+0216 and Alt+0177 work, but only after i type them out in the command line and then cut and paste into the text override field. (i tried the same with the Alt+030 code but that one still gets ignored) Has anyone else had a similar issue?
¡Resuelto! Ir a solución.
