Alfred.NESWADBA
en respuesta a: Anonymous
ok, thank you for clarification, I can see now the frame display you are referring to.
What I see is
the image is clipped
the image is set to transparency = 40
What I have found out for now: disabling transparency (setting the value to 0) results in not displaying the frame.
Am I correct that you are setting the transparency to 40 simply to lighten up the image? (as I can't see any objects behind the image-object) ... In that case I would prepare the image to have the more light appearance and then insert it without the need of transparency.
Option 2: prepare an image that is already larger then the biggest objects of your furniture and so there is no need to insert it multiple times, one besides the others ... and so you don't have borders between them.
For now I can't find a solution or a setting that creats a correct output (not showing the frames even all *FRAME* settings are turned off).
Sorry, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
