Alfred.NESWADBA
en respuesta a: Anonymous
which driver did you use when plotting to PDF?
I would suggest to use an AutoCAD driver like "DWG to PDF.pc3" or "AutoCAD PDF (General Documentation).pc3" and see if that helps.
If not can you please upload the dwg-file and let is know which version and update of AutoCAD you are using (command _ABOUT ==> screenshot).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
