Alfred.NESWADBA
en respuesta a: Anonymous
>> I tried to change the colour from black to white
Color 7 (which shows as black AND white) is one special color, that is the opposite of the background. So you can't use color 7 in that case. If you want to have anything real white you can use the true color tab and select e.g. 255,255,255 to get a clean white, but make sure in that case you are not working on white background, otherwise you would not see the text.
To your thread title:
>> change colour of text outline
AutoCAD's fonts do not have outlines, it's just one text with one color (no differentiating between outline color and filling color).
You might use ExpressTools function TXTEXP (>>>details<<<) to get outlines from a text (which needs a bit or reworking afterwards) ... that gives you separate outlines for your truetype font based text objects.
- alfred -
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
