10-24-2018
09:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-24-2018
09:09 AM
The only object enablers from Autodesk for AutoCAD1019 are here https://knowledge.autodesk.com/support/autocad/downloads
There are no others from Autodesk. Other software vendors may have some for you, but you need to know what that is: it looks like AutoCAD doesn't know either. Find out from the original file creator.
If those aren't going to help, then you need to ask the person that created your file to dumb it down for your use with their software's version of "save as autocad" feature.
Or you could go ahead and destroy all of those in the file yourself using AEC@ACAD command in 2019AutoCAD.
