- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Excuse my late reply, but it is already here 01:30 AM, lol.
Sorry, but this is another situation, your statement sounded as only the name changed, but it wasn't.
"I have 13,452 of these blocks in my base drawing. They were originally all just the same block"
For each block the objects are the same (i didn't check this, but it looks like that),
but for every block the objects are on different positions..so each block is different to the others.
In this case you can have to go another (tool) way:
Explode all, erase all objects except the same one of each block - for example the LINE.
Replace the Line with a Blockreference.
If you searching for a tool in the forum you will find a lot.
"convert circle to block" or "point to block" or similar topics.
A sample attached.
baseplanX= replaced with your new non-dynamic block (hint: In your arrays in the right, you are using the "*_old" dynamic block)
baseplanY= replaced with your "*_old" dynamic block.
Sebastian
