10-23-2018
11:25 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-23-2018
11:25 AM
@Anonymous wrote:
I have 13,452 of these blocks in my base drawing. They were originally all just the same block ....
If you either still have the original "same" Block definition [other Messages sound like you don't] or can make a new definition of it by Exploding a copy of one of the 13,452 set at 0 rotation and a scale of 1, and using its pieces for a redefinition, then you should be able to use BlockReplace.lsp -- available >here< -- to change them all to the new same Block definition. Use its BRS command, give it the new Block name, and select all the 13,452 [or do it in several passes with fewer at a time]. There are other routines out there you can Search for, to replace existing Block references with other Blocks.
Kent Cooper, AIA
