3009 Vistas, 4 Respuestas
Fatal Error: Unhandled Access Violation Reading 0x0000 Exception at 8e963907h
Hi I have had some problems with my Autocad lately, at first while I was using the program it just crashed for no reason sending me this message or a similar message with the "FATAL ERROR" on it. But I still could use it for a while. For example, I could use it for 2 hours and then it crashed, I woulld turn it on again and keep on working for another few hours.
But now it´s different, I can´t even get into the starting page, it just crashes when I open Autocad.
I have tried so many "solutions" of the problem that I have found online and in your website, like updating my video driver, uninstalling and reinstalling Visual C++, usin the /NOHARDWARE switch in the Target line and reinstalling Autocad, and it doesn´t work for me.
Please help.
john.vellek has embedded your image(s) for clarity
Alfred.NESWADBA
en respuesta a: Anonymous
Does that happen while working with one specific project? If so close the drawings, then open a new dwg-file, start command _RECOVERALL and select your dwg-file and see if AutoCAD finds errors in it.
Please start command _ABOUT and show us a screenshot from that dialog (please find here some tips about getting screenshots without the need of an external camera >>>click<<<).
Also please show us a screenshot of dialog _GRAPHICSCONFIG
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
It sounds like this installation is totally bad now. Can you provide a NFO for me to look at?
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
en respuesta a: Alfred.NESWADBA
Hi Alfred,
No it doesn't, it could be any file...
>>Please start command _ABOUT and show us a screenshot...
The thing is I can't open Autocad.
Thank You!
john.vellek
Hi @Anonymous,
Thanks for sending me your NFO.
You do have the latest Nvidia driver but we might try rolling back one or two versions to see if that helps.
The Intel card has a newer driver here.
It is possible that your Ccleaner might have been too aggressive and removed a registry key.
In your event error log,  I see that acaddm14.hdi is throwing an error. This appears to be a printer driver. I sent you a copy of mine in  email to try or to compare with the one you have installed.
Also, the AClauncher is showing a ntdll.dll error which is described here.
John Vellek
