10-19-2018
09:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-19-2018
09:20 AM
HI @Anonymous,
I see some applications that might be causing this issue: Malwarebytes, Ccleaner, Avira. You can try to remove these to see if it helps.
I do see that AutoCAD is failing from the error log with adapplicationframe.dll errors which are definitely .Net related errors. Please try running this tool to cleanup the .Net and then see if you can't uninstall .Net Framework and then reinstall it using the article I provided.
More importantly I see numerous utorrentie.exe errors which I believe are virus related.
John Vellek
