10-17-2018
10:22 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-17-2018
10:22 AM
New Tool?
Are you simply saving your .cuix file and loading that to the new ACAD install? If so you will do the same from PC to PC.
The .cuix file should bring all of your user interface look and feel to new versions but understand that sometimes new versions have some new elements that may not be the same as before. There should be no significant things to point out from 2016 to 2019.
Command CUI
Use transfer tab to ensure all elemnts are similar in left and right panels.
Save your new .cuix file to an easy location.
Copy the new .cuix file to the new PC.
Use the transfer tab again to load the new file in the left panel.
Hope this helps,
Blaine
