Nel_Zelpher
388 Vistas, 4 Respuestas
is there a way to export to bit map?
one of our program guys has received several acad files he needs to use in his software job.
Is it possible to export the dwg's as bit maps?
Alfred.NESWADBA
en respuesta a: Nel_Zelpher
simplest way and in most cases the best quality is to run command _PLOT and use "DWG to PDF.pc3" as device.
This will give a PDF as result which can be imported in most software.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Nel_Zelpher,
Here is an article that explains how to create a JPG export.  Similarly, you can utilize BMPOUT to create a bitmap.
In addition, PDFs and other raster formats can be produced using the PLOT command. You can also consider using a screen capture utility as well depending on the intended use and quality.
John Vellek
illusionistNUGXG
The free version of PDF Creator has been proven useful to me, if i needed a bitmap of a drawing.
When installed, you can choose it as device (like "DGW to PDF").
After pushing the OK-Button, the PDF Creator opens a window to assign a location for the save file.
In this window you can also chose different formats - JPEG, PNG, TIFF. (I prefer PNG)
Plot styles are applied - i never had any problems so far.
(but i still use "DGW to PDF" for PDFs)
john.vellek
Hi @Nel_Zelpher
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
