- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@s3690674 wrote:
Hi @Kevin.Palmer and @alex101000,
I tried to turn off the hardware acceleration and my workspace came back to normal. However, my cursor is very laggy. Sometimes it took up to a second or two to get to where I want it to be.
I also tried to uncheck the DPI scaling, but it seemed like nothing happened.
Is there any other way I can do to get my workspace but does not affect the cursor speed?
Please let me know,
Thank you.
Turning off hardware acceleration is more of a diagnostic tool than a solution. Because it "solves" the problem, it indicates your computer is having problems with the graphics system. Most commonly this is out of date or improperly installed GPU drivers, or a GPU auto-switching utility (common on laptops) getting in the way. Once you confirm those are correct, turn hardware acceleration back on in AutoCAD.
A quick point about your terminology: "workspace" in AutoCAD is a specific term. It refers to the layout of user interface items, like Ribbon panels, palettes, menus, and toolbars. You might consider using a different term such as "drawing area".
