cadffm
en respuesta a: Anonymous
We do not know your installation and adjustments,
you have to find what you have installed and set up yourself.
1. APPLOAD - StartUp suite
    empty?
2. (if (setq f (findfile "ACAD.lsp"))(startapp "notepad.exe" f)(alert "No Acad.lsp"))
    is there a load statement for other files or menu? Or s::startup
3. (if (setq f (findfile "ACADDOC.lsp"))(startapp "notepad.exe" f)(alert "No AcadDoc.lsp"))
4. Check also for acad2015.lsp and acad2015doc.lsp
5. Command: APPMANAGER (if installed)
    empty? If not installed take a look in your registry HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxxx\AutoLoader\Loaded\*
Sebastian
