Erense
en respuesta a: stefanveurink68AXD
If i understand correctly,
You take the first road line as basepoint.
Then you offset the measured distances for the second road.
Perpendicular to thes lines you have a (i assume) set distance between the measered points. (like 1 mtr)
Offset these lines and draw a pline over the intersection of the lines.
For obvious visibility reasons break the PLine into 5/10 points, remove the old lines, and only then offset the next few distances.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
