- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Once a open the CAD file, it shows the box of Enter name of customization file to load: as attached.
So the batch plot cannot be run regarding this issue.
Do everyone know how to solve it?
Thank you.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Damaged or missing AutoCAD settings files can cause this error. On Windows XP systems, in addition to having bad settings files, another reason for the error can be missing or corrupted Microsoft XML system components. Click here
Reinstalling Microsoft XML may be needed. To do this, go through Add or Remove Programs and uninstall everything that starts with "MSXML" and then download and install both of the following:
MSXML 4.0 Service Pack 3 (Microsoft XML Core Services)
Microsoft Core XML Services (MSXML) 6.0 Service Pack 1
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Look to me like you have Third party software included in your AutoCAD. Is this True?
Are there any default menu's loaded?
If so, Type CUI and check the Main customisaton File (should be AutoCAD.Cuix), and check the 'partial customisation files' for any that has the 'unresolved' extention to it.
Rightclick the Unresolved Cuix and choose Unload.
Open the drawing again.
Doe the error appear again?
If it is only this drawing there might also be some 'macro's ' embedded in the drawing which force the load of certain software.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you have all of your customizations backed up, try a software reset https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
OR... log into your PC as an all new user and see if the problem goes away (then you can always go back to your current log-in).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your reply, but I am using Windows 7 system.
And I have tried to reset AutoCAD setting to default, but the problem still persist...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your suggestion,
but when I check the 'partial customisation files' , there is no 'unresolved' extention as attached....
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try it in safemode:
https://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093A
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
O don't know your version/program path, but for plain Acad standard installation is that one possible way:
[Win]+[R] paste the next line into that console and apply
"C:\Program Files\Autodesk\AutoCAD 2018\acad.exe" /product ACAD /safemode
What is your version? > Screenshot of command ABOUT dialog.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
When I am using safe mode, the problem was fixed.
But may I know what is the issue behind that?
My AutoCAD version is AutoCAD 2015 and thank you so much for your solution.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Also how can I make the safe mode as my default AutoCAD launch?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
We do not know your installation and adjustments,
you have to find what you have installed and set up yourself.
1. APPLOAD - StartUp suite
empty?
2. (if (setq f (findfile "ACAD.lsp"))(startapp "notepad.exe" f)(alert "No Acad.lsp"))
is there a load statement for other files or menu? Or s::startup
3. (if (setq f (findfile "ACADDOC.lsp"))(startapp "notepad.exe" f)(alert "No AcadDoc.lsp"))
4. Check also for acad2015.lsp and acad2015doc.lsp
5. Command: APPMANAGER (if installed)
empty? If not installed take a look in your registry HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxxx\AutoLoader\Loaded\*
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Safemode ist for testing, not for usual work.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
1. I inserted a lsp for my work, nothing else.
2&3. I do not understand, may you explain more?
4. I just find acad2015.lsp as attached
5. It is not empty as attached.
Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
We know nothing about your lisp, so remove them and try it again.
Also, a s::startup is not defined in plain standard Acad2015
What is the feedback when you type in !s::startup
"2&3. I do not understand, may you explain more?"
difficult for me ![]()
The SketchUp-Plugin comes with a cuix, is this cuix reachable and loaded?
sketchupimportskp.cuix
Sorry, i can not explain all from here, thats a little bit too much.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
FILEDIA <1>
When FILEDIA is set to 0 (off), CUILOAD displays the following Command prompt.
Enter name of customization file to load: Enter a file name
Or
To reset a standard customization file Click here
Thanks You
Jayhar.M.J
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have removed it, but the problem still persists.
Command: !s::startup
nil
Yes, it is loaded as attached.
Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
FILEDIA <1>
The default value of "FILEDIA" is 1, the problem still persist no matter I changed to 0 or 1.
I reset it but "Enter name of customization file to load: Enter a file name" is still shown.
Thank you for your suggestion.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
