ChicagoLooper
en respuesta a: Anonymous
The sheet size, such as 11x17, is only available if the printer is capable of printing on a sheet that size. If your choice of printer can only print a maximum size of 8.5"x11.0" then 11x17 will not be available because the actual paper will not physically fit into the printer's tray.
You will either have to select another printer or choose a printer that makes electronic copies, such as a PDF, rather a printer that makes hardcopies.
Chicagolooper
