en respuesta a: ChicagoLooper
Thanks for the help Chicagolooper,
I ended up taking the advice of plotting all blocks again. This took me some time but at least it did the trick. Once I was finished, I gotta say the fact that measurements were in feet+inch was not an issue at all, meaning the only issue with the first file was that I had changed the UCS multiple times while inserting blocks.
The frustrating part about this is that even with those first blocks when I clicked on them, their properties tab was actually showing their correct XY position. It is very painful to see the software recognizing the information you need to extract, but not being able to compile them into the lists. Very frustrating!
Thanks for the help too!
