261 Vistas, 2 Respuestas
Fatal Error AutoCAD 2015
Can anbody help me and tell me why Autocad 2015 crashes everytime when I'm trying to print to my OCE TDS700 printer?!
Alfred.NESWADBA
en respuesta a: Anonymous
I would first try to create a new PC3-file using "add a plotter wizard" for that driver.
If that fails too update your OCE-driver and then again create a new PC3 for that new driver.
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Can you print to it from other applications using the installed WIndows driver? If yes, in AutoCAD PLOT directly to the Windows System driver that all the other apps use to print to it and see if the problem goes way.
BTW are you running Win10 by chance? Hope not https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
